In totale ci sono 66 utenti in linea: 14 Registrati, 0 Nascosti e 52 Ospiti :: 2 Motori di ricerca
Belpri, BoBoPoP, Francesco Pacchioni, giorgio jk, holY88, Lucs, mgnever, roccia88, rosair, scara, scarovas77, Tamarindo, yj black, ZANFO
» Buonasera a tutti
Oggi alle 17:16 Da Tamarindo
Oggi alle 13:52 Da Vicegta
» portapacchi ramingo 4x4
Oggi alle 10:46 Da Mud
» Ciao a tutti !!!!
Oggi alle 08:48 Da Strale
Ieri alle 19:22 Da giomba
Ieri alle 15:29 Da gfiocchi
Ieri alle 15:06 Da mgnever
Ieri alle 00:31 Da Alesmade
Tire ball
Tire ball
Messaggio  mgnever il Mer 26 Nov 2014, 09:12
Qualcuno ne ha mai sentito parlare?
Le ho trovate per caso su un sito americano:
The TIRE BALL® Company and ///EMERGENCY EQUIPMENT are pleased to announce this proven technology is available for distribution to all public and private emergency responders. Now, Fire / Rescue / EMS / EMA / SAR and Law Enforcement agencies can benefit from the same advantage off road racers and special warfare operators have enjoyed for years. With TIREBALLS added to your off road response vehicle or trailer, your tires are virtually Flat–Proof!
* Tires containing the TIREBALLS tire protection system use a multiple air cell design which allows puncturing of several cells without total loss of air pressure. As hazards are encountered, cells are individually deflated, while remaining cells expand to fill the void. As a result, off road rescuers safely continue emergency operations without stopping to repair a flat.
TireBalls
* Tires containing the TIREBALLS tire protection protection system safely allows your off road rescue vehicles to run with lower inflation pressures. Lower air pressure in tires results in expanding the tire’s contact patch. This improves your off road traction, while producing increased acceleration with shorter braking distances. Overall, your rescuers benefit from safer off road emergency vehicle operations.
* Tires containing the TIREBALLS protection system virtually eliminates tire sidewall instability. By acting as an inner tire bead lock, even at reduced tire pressures the multiple air cell design exerts internal pressure on tire sidewalls. This pressure holds the tire bead in place under lateral loading conditions, preventing the “rollover effect” and total deflation that frequently occurs in under inflated tires during emergency off road operations.
Racing ATV tire severely cut on the course.
While scarred, the TireBall held and the driver won the event!
* Tires containing TIREBALLS tire protection system produces an enhanced suspension effect. When the tire encounters an obstacle, air pressure is progressively increased at the point of contact as the multiple air cells are compressed. This produces a smoother ride, avoiding the “bounce effect” and protects your rims from sustaining severe impact damage.
* Tires containing TIREBALLS tire protection system allows emergency responders to 'accomplish the mission' and return to base where tire repairs are made before the next emergency off-road rescue mission is dispatched.
Re: Tire ball
Messaggio  Bum Bum il Mer 26 Nov 2014, 09:28
figata.... ma per poi rigonfiare come fai?
Re: Tire ball
Messaggio  mgnever il Mer 26 Nov 2014, 09:32
Proprio per quello volevo sapere se qualcuno ne ha sentito parlare perchè non ho trovato tante spiegazioni in merito Mad
Pare che per ora sia solo per 38,39,40,41 e 42 come misura di gomme.
Il sito è questo http://www.tireballs.com/
Re: Tire ball
Messaggio  ilpitagora il Mer 26 Nov 2014, 15:15
Le avevo provate sulla moto, idea geniale, una vera rottura di scatole da gestire. Per fare la pressione ogni volta devi tirar giù la gomma dal cerchio e gonfiare una ad una le singole camere.
By IlPitagora
ilpitagora
Data d'iscrizione : 14.04.11
